cdnadmin
Community Member
This document was generated from CDN thread
Created by: Solomon Luke on 16-02-2010 11:23:31 PM
Is it possiable to play flash .swf files on cisco IP phones? If so can some one point me in the right direction.
Solomon
Subject: RE: Shochwave Flash
Replied by: Anitha V on 17-02-2010 07:05:57 AM
Hi Solomon,
As of now, .swf files are not supported in Cisco IP Phones.
Thanks and Regards,
Anitha
Replied by: Solomon Luke on 18-02-2010 01:11:01 AM
Is it then passiable to use the Idle URL service to dispaly number of diffrent pictures while the phone is idle?
Solomon
Replied by: David Staudt on 18-02-2010 04:39:51 AM
That is much more possible.  The Idle URL could point to a web server URL that returned a CiscoIPPhoneImage/ImageFile object, setting the Refresh: header to load the next image's URL after X seconds.  E.g.:
HTTP/1.1 200 ok
Refresh: 10; url=http://www.example.com/getNextImage.php
Replied by: Solomon Luke on 24-02-2010 10:12:32 PM
I have the idle url working. I am not sure how to set the refresh to go to the next picture? Can you please explain a bit in detail how to get this working.
Solomon
Replied by: David Staudt on 25-02-2010 01:26:01 AM
The end result you want is to get the HTTP header 'Refresh:' added to your response to the phone:
How to do that depends on what CGI platform you are using on your application web server.  See this link for an example using PHP:
http://www.desilva.biz/php/phprefresh.html
Note, the URL you provide needs to be to the next image (i.e. CiscoIPPhoneImage/ImageFile) you want to display.
There is an .asp based sample that does something like this in the IP Phone Services SDK: http://developer.cisco.com/web/ipps/docs
Replied by: Solomon Luke on 25-02-2010 05:54:52 PM
Thanks David for pointing me to the IP Phone Services SDK. I used the ¿pngviewer¿ as IP phone service and set the parameter refresh to 10 and it worked, the pictures changed very 10 sec.
I want to achieve the same result not as a phone service but when the phone is idle. I used the same url that I used in phone service and pasted in the idle url and got the phone to display the first picture.
What do I edit in the pngviewer.asp to get the pictures refresh every 10 sec? The file is attached.
As you tell I have no idea about scripting. I very much appreciate your help.
Solomon
Replied by: David Staudt on 25-02-2010 07:30:58 PM
I think all you should need to do is add the refresh parameter to the URL you have in the Idle URL box:
http://myserveraddress/jpegviewer.asp?refresh=10
This is handled automatically by the parameters function when you provision as a service, but you have to do it manually for an Idle URL.
Replied by: Solomon Luke on 26-02-2010 12:01:03 AM
Thanks David. That got the pictures rolling.
Solomon.
Replied by: Solomon Luke on 25-03-2010 12:13:08 AM
Hi David,
Is it possiable to remove the blue border that has the file name "Oak.png"? or hide the file name? Please see the attached picture.
Solomon
