Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Jason P Holland on 02-11-2010 03:13:40 PM Hello, I'm trying to get a simple PHP script written to query AXL. This is on CUCM 7.1.5. -------------------- <?php $client = new SoapClient("/home/www/html/soap/AXLAPI.wsdl", array('trace'=>true, 'exceptions'=>true, 'location'=>"http://server1:8443/axl/", 'login'=>'user', 'password'=>'*****', )); $response = $client->getUser(array("userid"=>"mholland")); var_dump($response) $response=$client->getLine(array("pattern"=>"911")); var_dump($response); ?> --------------------- The response I'm getting back is
PHP Fatal error: Uncaught SoapFault exception: Error Fetching http headers in /home/www/html/soap/soap_test.php:11 Stack trace: #0 [internal function]: SoapClient->__doRequest('<?xml version="...', 'http://server1:8...', 'getUser', 1, 0) #1 /home/www/html/soap/soap_test.php(11): SoapClient->__call('getUser', Array) #2 /home/www/html/soap/soap_test.php(11): SoapClient->getUser(Array) #3 {main} thrown in /home/www/html/soap/soap_test.php on line 11
Can someone offer some help? I was able to use __getFunctions to return a list of SOAP functions, so appears that things are working. But simple calls don't seem to work. Thank you!
Jay
Subject: RE: Simple AXL and PHP Script Replied by: Jason P Holland on 02-11-2010 09:32:09 PM I seem to have found the solution to this. For those searching for an answer, I had to get a new AXLAPI.wsdl file from the axlsqltoolkit.zip file. Had to use the version from axlsqltoolkit\schema\7.1\WSDL-AXIS\. Seems to be pulling information just fine now. Jay
