This document was generated from CDN thread
Created by: Adva Rotstein Hayun on 06-09-2010 08:24:34 AM
I use the simulator to login 300 agents.
Now I would like to send calls to those agents.
Do you knwo of simulator has any command line prompt that can enable scripts to send these calls?
or at all using command line to perform operations?
So far I saw only the configuration is in the command line.
Adva
