Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: DANIEL EDWARDS on 25-10-2008 02:36:30 AM I am trying to pull all phones currently on the a CUCM6 system via SOAP RisPort and the samples I found work like a champ. The only issue is that the examples cap the results to 200 results. No matter what I change this number too I only get the first 200 results. Needless to say I have clusters with more than 200 devices. Anyone have an idea of how to get more results?
Subject: Re: SOAP Request MaxReturnedDevices Issue Replied by: David Staudt on 25-10-2008 03:35:34 AM 200 is the limit. In order to retrieve more, you will need to get a list of the possible devices say, (via AXL configuration API,) then submit 200 at a time via SelectCmDevice.
Subject: Re: SOAP Request MaxReturnedDevices Issue Replied by: Stephan Steiner on 27-10-2008 08:57:57 AM Also, you might run into this later on: You may not get the same number of results than you queried for since RisPort never returns devices in status unknown - so if you need those, after you make the query you compare results and request and you know that the delta are the unknown ones.
Subject: RE: Re: SOAP Request MaxReturnedDevices Issue Replied by: Adam Farmer on 03-07-2009 09:55:27 AM Hi. Do you know what AXL call is required in order to get a list of all possible devices so that i can then submit 200 at a time via SelectCMDevice?
Subject: RE: Re: SOAP Request MaxReturnedDevices Issue Replied by: David Staudt on 03-07-2009 04:50:36 PM listPhoneByName with <searchString> being a wildcard '%' will return everything. Take care with this query as the return object can be very large (for a large site) and could trigger AXL request size throttling.
