cdnadmin
Community Member
This document was generated from CDN thread
Created by: Matthew Taylor on 15-12-2009 04:39:46 AM
G'day,
I am using an AMX system to control the following.
MXP 6000 F6.3 (connected to the AMX serially)
TVS
Tandberg HD camera on DVI Input 1 and control input 1 (camera 😎
Sony HD1 on Component input 5 and control input 2 (camera 2)
I can control PTZ on both cameras but I can only store/recall presets for the Tandberg camera.
The presets recall the correct video input on the switcher but do not control the Sony camera.
I have tried mapping the inputs with the following commands without success.
xconfiguration Switch LogicalInput 1 Map: 1
xconfiguration Switch LogicalInput 3 Map: 5
xConfiguration Switch LogicalInput 3 Mode: On
xConfiguration Switch LogicalInput 1 Mode: On
Am I missing something?
Should the CODEC store presets for the Sony camera?
Any help would be much appreciated.
Cheers
Matthew
Subject: RE: Sony Camera Presets
Replied by: Roger Boe on 17-12-2009 12:48:06 PM
Hi Matthew,
Have you connected the Sony HD1 camera to the TANDBERG PrecisionHD 720p camera using a daisy chaining cable? The control for the Sony camera must come from the daisy chain port of the TANDBERG PrecisionHD 720p camera. I have attached you pin out for this cable. The 2nd control output of the TVS is for a second camera chain using the old TANDBERG Wave Cameras.
Best regards
Roger
Replied by: Matthew Taylor on 20-12-2009 11:13:14 PM
G'day Roger,
Thanks for that.
I will have the camera connected to the daisy chain and let you know what happens.
Cheers
Matthew
