cdnadmin
Community Member
This document was generated from CDN thread
Created by: Gionata Navarra on 22-06-2010 03:50:40 PM
Hi all.
I've used Axl on CUCM 7.0 to retrieve data about EndUsers.
With a simple query I obtained informations requested but trying to aggregate results with GROUP_CONCAT I have following exception:
javax.xml.ws.soap.SOAPFaultException: Routine (group_concat) can not be resolved.
    at com.sun.xml.ws.fault.SOAP11Fault.getProtocolException(SOAP11Fault.java:189)
    at com.sun.xml.ws.fault.SOAPFaultBuilder.createException(SOAPFaultBuilder.java:130)
    at com.sun.xml.ws.client.sei.SyncMethodHandler.invoke(SyncMethodHandler.java:119)
    at com.sun.xml.ws.client.sei.SyncMethodHandler.invoke(SyncMethodHandler.java:89)
    at com.sun.xml.ws.client.sei.SEIStub.invoke(SEIStub.java:118)
this is the query:
"SELECT EU.userid, D.name, GROUP_CONCAT(NP.DnOrPattern) from Enduser EU, Device D, DeviceNumPlanMap DNPM, NumPlan NP WHERE D.fkEnduser==EU.pkid AND D.pkid==DNPM.fkDevice AND DNPM.fkNumPlan==NP.pkid GROUP BY EU.pkid, D.pkid"
I've added GROUP_CONCAT to obtain a single instance of each EndUser with a list of multiple lines, and not an instance of EndUser for each line.
E.g: User A with 3 lines
Expected res:
User A --> line1, line2, line3
and not:
User A --> line 1
User A --> line 2
User A --> line 3
Is there any other way to aggregate fields?
Thank you
Gionata Navarra
Subject: RE: Sql aggregation function with Axl
Replied by: David Staudt on 22-06-2010 05:45:56 PM
As far as I can tell GROUP_CONCAT is not supported by the UCM database engine, Informix Dynamic Server 10.
SQL reference for IDS here: http://publib.boulder.ibm.com/infocenter/idshelp/v10/index.jsp?topic=/com.ibm.sqlr.doc/sqlrmst03.htm
Replied by: Gionata Navarra on 02-07-2010 06:56:44 AM
thank you.
