This document was generated from CDN thread
Created by: James Maudlin on 07-06-2011 09:43:41 AM
Having sporadic issues with SSL ¿ I think. Some, links are getting created with non-SSL and that is causing issues.
For example, when I create Communities, it comes up with the following error:
All Communities is temporarily unavailable.
Try the following.
1. Make a backup copy of your /opt/cisco/WebEx Social/tomcat/webapps/ROOT/WEB-INF/classes/ portal-ext.properties file
2. Add the following properties and values to /opt/cisco/WebEx Social/tomcat/webapps/ROOT/WEB-INF/classes/ portal-ext.properties
a. company.security.auth.requires.https=true
b. web.server.protocol=https
c. web.server.http.port=80
d. web.server.https.port=443
e. webdav.servlet.https.required=true
3. Restart WebEx Social
Subject: RE: SSL Issues
Replied by: ROD TAGUCHI on 12-09-2011 08:19:16 PM
Hi James,
What version is this referring to?
Rod
Replied by: James Maudlin on 12-09-2011 08:25:43 PM
2.1 - similar to what you have.
Replied by: Kalin Sheytanov on 10-10-2011 05:29:34 AM
Folks,
Just go provide a short update. From version 2.5 onward config changes are not done by directly editing portal-ext.properties.
They need to be performed on the CPS/Director node as they are now stored in the database. This means that upon restart pupped will wipe any changes made to the file directly, by pulling the original configuration from the CPS node.
Kalin.
