This document was generated from CDN thread
Created by: null on 27-01-2006 04:01:08 AM
In Studio 5 we are routinely getting Eclipse exceptions for Stack Overflow: Requesting Java AST from selection. This is a bug that was supposed to have been fixed in Eclipse. I followed directions on the Eclipse site to upgrade the Eclipse environment in Studio to v3.1.2 but I am still getting this error often. The only way to have the exception box stop popping up is to click somewhere else on the code editing window. Is there a fix that you know about for this?
Subject: RE: Stack Overflow Errors in Studio 5
Replied by: Vance Vagell on 27-01-2006 03:23:28 PM
Hi Rich,
As of Audium Studio 5.0.1, this has been resolved. You can use Audium Studio 5's built-in Software Updates feature (Help -> Software Updates) to upgrade to the latest version which is 5.0.2. Once you have upgraded, please be sure that the latest version of framework.jar is being used by your Java projects. It can be found in the following directory:
Studio\eclipse\plugins\com.audiumcorp.studio.library.framework_X
where X is a version number.
Please let us know if you continue to encounter this error dialog after updating and referencing the new framework.jar.
Vance
Replied by: null on 01-03-2007 12:22:05 PM
Hi.
One of our customers is getting a different form of stack overflow error in building Studio decision elements with a fair number of clauses (using the decision editor).
This is with Studio 5.0.3, but I couldn't see any bug fixes in later releases which seemed to relate to this. Is this a known problem and, if so, is a fix in an existing Studio release??
I've attached a screenshot. If it happens again, I've asked the customer if they can capture any Audium Error Log data - assumed this is the ".log file" the error box refers to (right?)....
Thanks in advance.
Stuart
Replied by: Cheng-Dar Yang on 02-03-2007 09:11:40 PM
Hi Stuart,
The issue you are describing sounds similar to a known issue where stack overflows can occur while using Decision Editor. The issue exists in our internal issue-tracking system with ID of CSCsh41587.
In order for us to determine if the issues are the same, please provide the following:
1. - Detailed steps to reproduce the error.
2. - The Audium Error Log ".log" file.
Cheng
Replied by: Janine Graves on 07-03-2007 05:26:49 PM
FYI, I believe some people who experienced this problem found that shortening the name of their elements (and maybe of the variables) actually 'fixed' the stack overflows.
Are your element and data names very long? try shortening the names and see if this is a work around for you.
Replied by: null on 23-03-2007 10:48:55 AM
Sorry for the delay.
I managed to reproduce the problem (on Studio 5.0.3 as per our customer). Not every time, but adding 6 or so expressions to a decision element tends to cause it. Same error as before and the .log file has contents as below:
!SESSION 2007-03-23 10:38:49.66
eclipse.buildId=I20050627-1435
java.version=1.4.2_06
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86 -data eclipse\workspace
!ENTRY org.eclipse.ui 4 4 2007-03-23 10:43:00.222
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2007-03-23 10:43:00.253
!MESSAGE java.lang.StackOverflowError
!STACK 0
(I should point out that it's very unclear where this .log file is supposed to be!! For those reading, it's in your workspace\.metadata folder).
Can you confirm if this is symptomatic of the open issue you mentioned? From the wording, I assume that this issue is not yet fixed.
Janine - the long name doesn't apply in our case. The decision element's just called "Has Services".
Thanks in advance.
Replied by: null on 23-03-2007 10:54:01 AM
Sorry, should also point out that a colleague is running Studio 5.2 and doesn't seem able to reproduce the problem. So maybe the decision editor improvements there have fixed this symptom??
Replied by: null on 23-03-2007 05:51:19 PM
Hi Stuart,
Thanks for taking the time reproducing the problem and sharing your insights on potential causes!
We have confirmed that the above mentioned known issue, with the ID of CSCsh41587, is indeed intended to fix this problem. The issue is currently still open in our internal issue-tracking system, and we have updated it with your comments. Please refer to that ID in the future to check the status of this issue.
Rachel
