Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Janine Graves on 19-03-2009 10:20:07 PM I see in the CAG that in CVP 7.0.2, ICM can play streaming audio in its PM microapp. Does anyone know if this can also be done using Studio? If so, how? And what is possible - is it possible to hook up to a live audio feed? Or is it just to play a long audio recording without loading it first to the Vxml GW? Are there performance issues? Thanks, Janine
Subject: RE: Streaming audio Replied by: WILLIAM WEBB on 19-03-2009 10:32:52 PM I posed this very question to the PDI Help Desk, and they are looking into an answer. One technical note - it requires the use of IOS 12.4(20)T train code, just so you're aware. At least to be officially supported in production. The IOS gateways have been able to support RTSP for a long time now. As for the process, it is something that we speculated could be possible, and we actually tried it a while back. We were able to start the stream, we just couldn't stop it. Interestingly enough, if you read the release notes, all it sounds like they did was add a timeout config parameter to the Play Media microapp to - surprise - stop the stream! 😉 My guess is that it will still be an issue in Studio because there is nowhere to define the timeout parameter (as far as I've seen), but I'll update the forum with any information I get back from PDI! As to your other question - basically anything that you can access via RTSP can be used, theoretically. You're simply changing the request from: http://mediaserver/prompt.wav to rtsp://streamingmedia/stream.rm - Bill
