on 01-24-2014 03:18 PM
Hi Hemal, I assume what they want to do is: 1. Have ICM queue the call 2. Send the call into Studio app, 3. The Studio app starts an audio stream on the gateway that should play music, while the Studio app (VXML Server) does some DB dip or goes to a web service ("we can do some other checks while the call is in queue.") 4.Once the DB dip is done, it seems like they want to end the streaming audio and perhaps send the call back to ICM. I don't really see what the problem with my solution would be. If there is an issue, please let me know. Also, not sure whether Cisco IOS supports 'audiofetchhint' with the value 'streaming'. Do you know? Thanks, Janine On 10/3/2011 5:50 PM, Cisco Developer Community Forums wrote: Hemal Mehta has created a new message in the forum "General Discussion - All Versions": -------------------------------------------------------------- Janine, Just to clarify. Some fetch/backend dip needs to be executing in the background while this plays. What if the user is calling this RTSP stream from audio element and is executing something like: <property name="audiofetchhint" value="stream"/> <audio src="⿦⿦⿦⿝/> Hemal From: Cisco Developer Community Forums [mailto:[email protected]] Sent: Monday, October 03, 2011 4:20 PM To: [email protected] Subject: New Message from Janine Graves in Customer Voice Portal (CVP) - General Discussion - All Versions: Re: New Message from Manny Berenjian in Customer Voice Portal (CVP) - Gener Janine Graves has created a new message in the forum "General Discussion - All Versions": -------------------------------------------------------------- Here's how to do what you want: You can set the audio stream to be your 'fetchaudio' and then it'll only play until you send the next VXML page (voice element in Studio) to the gateway. Set the VoiceXML Property Name: fetchaudio Value: (your audio stream URI) Set the VoiceXML Property Name: fetchtimeout Value: 360s (this gives you up to 6 minutes to complete your task) On 10/3/2011 4:49 PM, Cisco Developer Community Forums wrote: Manny Berenjian has created a new message in the forum "General Discussion - All Versions": -------------------------------------------------------------- This is for a RTSP stream that theoretically never ends. WIth a microapp, we can set a timer for it, and bring it out of the ICM node. Am needing to do similar in Audium, so the stream doesnt play for ever, and we can do some other checks while the call is in queue. -- To respond to this post, please click the following link: <http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/4567052> or simply reply to this email. -- Janine Graves -- To respond to this post, please click the following link: <http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/4567109> or simply reply to this email. -- To respond to this post, please click the following link: <http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/4567203> or simply reply to this email. -- Janine Graves
