Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Trond Bakaas on 10-12-2010 10:18:03 AM We have a problem with global phonebook and TC4.0 on a c60. Sip-entries turn out as SIP:sipnumber@domain.com in the command line interface, but trying to call numbers on this format the system reports:
*r DialResult (status=error): Cause:10 Description: Specified dial protocol is turned off **end
Changing SIP to sip in the dial-string makes the call go through.
This changed bahaviour is a problem when using the Crestron module to set up calls.
Trond Bakaas
Subject: RE: TC4.0: case sensitive call setup? Replied by: David Bruun-Lie on 10-12-2010 11:41:54 AM Hi Trond, Hm, there is something strange here and it seems to be configuration dependent. I'm going to send you an email so you can send me some more details on your setup 🙂
