cdnadmin
Community Member
This document was generated from CDN thread
Created by: Jesse Auner on 23-08-2010 02:40:50 PM
Is there a way to make a TCL Script that uses  plays a Wav file when you dial extension?  The wav file would need to play over an extension that has a PA system attached to it.  I would like the script to work like an auto attendant.  Press 1 for one wav file and press 2 for another and play that wav file about 10 times.  I would also like it to ask for a numeric password before giving you the options.
Does anyone have a script similar to this?  I am really new to TCL programming.
Subject: RE: TCL Script for Paging
Replied by: Yaw-Ming Chen on 23-08-2010 02:51:43 PM
Yes, that's doable.
I think you can use its-CISCO.2.0.2.0.tclhttp://www.cisco.com/cgi-bin/Software/Tablebuild/doftp.pl?ftpfile=cisco/access/tclware/its-CISCO.2.0.2.0.tcl&app=Tablebuild&status=showC2A
to modify.
Thanks !
