Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: null on 29-01-2004 08:48:37 PM I am trying to test a generic decision element using a URI. The Generic Decision has two exit state, Yes and No. I have the application post to a page yesno.asp. The ASP page contains:
</result> <exit_state>yes</exit_state> </result>
Is this even close?
All I want to do is return the exit state as yes. I am testing If I have the proper syntax, then I will worry about writing the asp.
Thanks.
Subject: RE: Testing Generic Decision Element Replied by: Michael Bochynski on 29-01-2004 09:44:29 PM Hi Matthew,
Actually, there are two minor isses with you code. The opening tag for the Generic Decision Element should be <result> not the </result>. The other issue is the header of the XML file. The first line of the generated XML should contain the XML definition - <?xml version="1.0" encoding="ISO-8859-1"?>
