cdnadmin
Community Member
This document was generated from CDN thread
Created by: Benek Ozer on 25-05-2011 04:08:36 AM
Is there a an actual way or a trick to produce CVP logs (activity log, error log, custom-written log, etc) when debugging an application in Call Studio?
Thank you for your inputs in advance.
Subject: RE: Testing Loggers from Call Studio
Replied by: Althaf Bealdar on 25-05-2011 04:36:11 AM
Please refer to the path "C:\Cisco\CallStudio\eclipse\plugins\com.audiumcorp.studio.debug.runtime_X.X.X\AUDIUM_HOME\applications\<Application Name>\".
Here you can find your application activity logs , error logs etc.  in Debugg mode.
regards,
Althaf.
Replied by: Benek Ozer on 25-05-2011 05:43:01 AM
Hi Althaf,
The logs were located there. Thank you very much!
Subject: RE: New Message from Benek Ozer in Customer Voice Portal (CVP) - General Di
Replied by: Hemal Mehta on 25-05-2011 09:15:39 AM
The logs are always there. Not sure, why you can¿t see them. Which dir are you checking ?
Hemal
From: Cisco Developer Community Forums [mailto:[email protected]]
Sent: Wednesday, May 25, 2011 3:09 AM
To: [email protected]
Subject: New Message from Benek Ozer in Customer Voice Portal (CVP) - General Discussion - All Versions: Testing Loggers from Call Studio
Benek Ozer has created a new message in the forum "General Discussion - All Versions":
To respond to this post, please click the following link:
<http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/3938999>
or simply reply to this email.
