TCC_2
Level 10
Level 10
Core Issue
This behavior is not consistent with the 7960 or 7940 phone, where the exit button screen is not displayed during login or logout.
This issue is documented in Cisco bug ID CSCee26663.
Resolution
To resolve this issue, update to Cisco CallManager 3.3(4)sr1a or 4.0(1)ES20.
Problem Type
Call control software (CallManager, CallManager Express, ICS7750, SRST, SS7 call agents)
Call Control
CallManager
CallManager Features
Bad operational behavior, status,information, performance, delay or other CCM failure
Extension mobility and services
Failure Type
Incorrect tone, music, greeting, prompt, message, announcement, etc.
Incorrect destination, sequence, number of rings, state, indication, result or other outcome
CallManager Versions
CallManager 4.0
CallManager 3.3
IP Phone Models
7970G
IP Phone Software
IP Communicator
