cdnadmin
Community Member
This document was generated from CDN thread
Created by: David Stimson on 15-03-2011 02:39:26 PM
We have a TMS with two systems (type = room). We can book them individually using the 3rd party API.
When we try to book both systems in one conference we get:
No route possible between participant: Test system 1 and participant: Test system 2
How do I configure these, or two other systems so that we can book two or more systems in a conference? We do not have any physical endpoints on this test system and only wnat to test the API.
David
Subject: RE: TMS Testing - add route between test system
Replied by: Torgeir Johansen on 15-03-2011 04:46:19 PM
David,
as TMS can not make a route (dial in or dial out) if you have no physical endpoint added, I'm afraid your use case is not possible.
Torgeir Johansen
