cdnadmin
Community Member
This document was generated from CDN thread
Created by: Ruel Reyes on 20-06-2011 07:33:25 PM
Hi Guys,
Can you guys suggest what is the correct command of controlling TTC7-14 Camera? I am using 'key up', 'key down' etc. for near end cameras and 'fecc up', etc for far end camera. It works smooth during my first programming but after two days, again camera control does not become smooth.
I try to resolve by using a higher Baud Rate on RS-232 and it works again for around 2 days and after that, again the same problem appear.
Do I need to send any command that will set the speed first?
Thanks. Your help will be greatly appreciated.
P.S. > I am using AMX to control TTC7-14.
