Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: ROD TAGUCHI on 22-06-2012 01:00:17 PM I have a question about undeleting data.
If someone actually happens to delete all of their content, can an administrator restore their deleted content?
Thanks Rod
Subject: RE: Undeleting posts Replied by: Ratnadeep Ray on 05-07-2012 05:49:55 AM
Thanks Rod
Hi Rod, If you have deleted any post, then you can restore this from the Trash folder. For this you do not need any help from the Admin. However for the rest of the contents, currently there is no option to restore after deletion. Regards, Ratnadeep.
