cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 31-10-2006 03:45:01 PM
Folks,
I'm getting reports from a customer regarding a session variable tha has a URI value including arguements after the question mark.
They are telling me that the XML API response with the sess variable is malformed and not fully sent to them (but half chopped off).
I'm still investigating but this seems odd behaviour. Has anyone else seen this?
Subject: RE: URL problems within XML
Replied by: null on 31-10-2006 04:01:14 PM
Just to clarify the session variable containing this URI information (with arguments) is passed in the XML API dynamic response to IIS.
IIS is getting the page malformed and half the XML is missing. It appears the session variable with the URI reference is causing problems.
when they take the arguements out the page works fine with a simple URI reference.
Replied by: Vance Vagell on 01-11-2006 10:29:36 PM
Hi Karl,
Does the problematic URL contain any characters that might result in invalid XML, such as characters that would need to be escaped? Please post the URL to this thread (as a text file attachment, so that the forum does not alter its display) so that we can check for any potential issues.
Vance
Replied by: null on 02-11-2006 12:45:07 PM
Will do vance! Waiting on the customer!
Cheers
Replied by: null on 03-11-2006 12:53:23 PM
customer tells me it was simply a URI with question mark followed by sessionid=XXXXXXX
Cheers
Replied by: Vance Vagell on 08-11-2006 10:39:22 PM
Hi Karl,
Please provide a simple test application that demonstrates this issue, so that we can reproduce it in our environment. The app can be as simple as a single element that sets up the requires session variables and then calls the external system (via the XML API). Once we have replicated this problem, we can work towards a solution.
Vance
