cdnadmin
Community Member
This document was generated from CDN thread
Created by: BRAD CLARKE on 07-10-2009 07:31:01 PM
I'd like to be able to use "*" as a valid input with the Digit Element , instead of an abort char.
I don't see any way to do this like we can with the termchar vxml property.
I need to be able to collect a string of DTMF digits, for example *70, and save them to session / element data.
For now I have used a Phone number element , and converted the "-" the Phone Number element creates back to a "*"
Subject: RE: Using * as valid input with Digit Element
Replied by: Ranjana Narayan on 12-10-2009 10:03:20 AM
Brad,
"*" entered for a Digit element throws a nomatch and this is per the VXML Spec.
You can instead try to use a Form element, and define the dtmfkeypress wit a metacharacter like "\*", this would generate the form vxml grammar as <grammar type= ¿application/grammar+regex¿>\*</grammar> which would match a literal asterisk (star) key.
Else, you can continue to use your workaround, to collect "*" in either Phone (* returned as X) or Number (* returned as . or + or -) and then convert it into "*".
Hope this helps,
Ranjana.
