cdnadmin
Community Member
This document was generated from CDN thread
Created by: Ravi Chandran on 12-02-2009 01:00:50 PM
I am trying to use the Database element, and the procedure in the document says I need to configure a JNDI in the Java application server (Tomcat). I do not have the manager user id and password to login to Tomcat, I tried the paswords found in tomcat-users.xml file , that did not help to login.
I would like to know if my approach is right, if yes where should I find the manager userid for Tomcat web server.
Subject: RE: Using Database element
Replied by: Janine Graves on 12-02-2009 05:29:50 PM
The default user/password for Tomcat when it's installed by Vxml Server
is  usually admin (user) and admin (pwd)
but whoever installed your Vxml Server might have changed that.
It's stored right in the tomcat-users.xml file though, so that should work.
If you have the admin tool, then you need a user in tomcat-users.xml the 2 roles admin
and manager as follows:
roles="admin,manager"/>
BUT - The browser-based Tomcat 'admin' tool to configure JNDI,
no longer
comes with Tomcat. You must download it from the internet.
AND if you do download the admin tool, then you'll
need to add a user to the tomcat-users.xml that has the 2 roles admin
and manager (for example,
BUT, keep in mind that you can also configure Tomcat for JNDI my modifying the server.xml
file directly if you know what to put in there.
Janine
Replied by: Ravi Chandran on 12-02-2009 06:08:54 PM
Thanks, do you have an example on what to add in server .xml to configure a JNDI
Ravi
Replied by: Ranjana Narayan on 13-02-2009 05:08:42 AM
Hi Ravi,
If you do not have a downloaded Tomcat admin utility tool, you can configure JNDI for VXML server by following steps mentioned @ http://developer.cisco.com/web/cvp/forums/-/message_boards/message/1057458  . Pls have a look at the "VXML Server Configuration" section of the article.
Hope this helps,
Ranjana.
