This document was generated from CDN thread
Created by: null on 09-05-2003 02:08:23 PM
"I'm using Nuance VWS, and found (pg 46 of the user guide) that for external grammars the slot must be called foundation_fld. I did that and got the slot value returned in the value element data. "
I found this message in this forum, and I'm wondering where I can find more documents on using external grammar file.
I would like to be able to capture the data when somebody speaks the right word in the grammar. I believe I can do this in Form element, but where is the data being captured?
Daniel Yoon
Subject: RE: using external grammar
Replied by: null on 09-05-2003 09:07:30 PM
Hi Daniel,
More information is available regarding the Form element in the Element Specifications document. This document also describes how grammars in other elements can be overridden. If you cannot find your answer in this document, please post any specific questions.
Joe
