cdnadmin
Community Member
This document was generated from CDN thread
Created by: santosh dandey on 09-03-2012 10:53:45 AM
We are in the review process to utilize Spring Framework mainly JDBC Template, WebServices, AOP for our back-end integrations. Did anyone used Spring Framework for CVP call studio applicaiton development.  If yes, where do we need to place the spring jar files? What additional configuraitons we need to make it work for CVP?  Please advise,
Subject: RE: Using Spring Framework as a back-end for Call Studio Applicaitons
Replied by: Hemal Mehta on 11-03-2012 07:24:15 PM
You can consider putting under Tomcat/common/lib if it is going to be used by several apps,
