cdnadmin
Community Member
This document was generated from CDN thread
Created by: Charles Fuller on 30-01-2009 01:06:01 AM
Welcome to the Cisco-Webex Meeting Service developer community.  These
forms are a great source of informational wealth for any development project on
the WebEx collaboration platform.  I want to personally welcome you and invite you to
have a look around.
These forums are set up in a logical way to allow you to
search, post, or subscribe to different categories and threads.  Please
review each section below for a quick ¿How to¿ to help you get started.
Please note that some features within the forum will be
disabled unless you are logged in with a valid developer account.  To sign up for an account please visit the
following link https://tools.cisco.com/RPF/register/register.do
Searching the forums:
Not sure where to post your question? Want to make sure your
question hasn¿t already been answered?  Then start off by doing a
search.  One of the easiest and most useful features of this forum is the
search function.  To use the search feature, locate the search box at the
top of each page on these forums.  Simply put in your query and click on
the button labeled ¿Search Messages¿.  It¿s that easy!
Creating a new thread:
Can¿t find what you are looking for with the forum search
feature?  Did you find out something that you think everyone should
know?  Then Post your question or comment to the forum.
First make sure you are in the category that best suits your
question or comment.  Next you will need to click on the ¿Post New Thread¿
button.  When you see the ¿Add Message¿ page, start off by typing in a
subject for your new discussion thread.  Next in the body section you can
type in your question or comment.  By using the edit controls on the top
of this window you can cut, copy, paste, add images, add links, and just about
anything else an advanced text editor will allow. If you are posting a
question, please make sure to check the ¿Mark as a Question¿ option.  If
you would like to tag your thread, you can type in a tag word and then add it
with the ¿Add Tags¿ button.  If you want to quickly add multiple tag
words, separate each one by a space and then click the ¿Add Tags¿ button.
Once you have everything set up, you¿ll want to make sure
that your question or comment looks the way you want it to.  You can do
this by clicking on the preview button at the bottom of the page.  If you
are not satisfied with how it looks, make the needed modifications and click
the preview button again.  You can repeat this as many times as you like.
Once you are satisfied with the look of you post you can add
additional attachments, or click on the ¿Save¿ button at the bottom of the
screen to submit your post.
Congratulations you have just created a new thread!
Replying to a post:
As you are browsing the forums you may want to comment on,
or answer a previous post.  You have two options:
Reply
or
Using the ¿Reply¿ link will bring you to the ¿Add Message¿
page.  From here you can continue to reply to the post the same way as you
would create a new thread.  Please review the ¿Creating a new thread¿
section above.
If you use the ¿Reply with Quote¿ link you will have the
original post in a quote box.  You can delete any of the original quote
that you do not need.  If you would like to quote more then one section of
the original post you can place your cursor at the beginning of the quote and
press the enter key.  This will create a second quote box with the
remainder of the quote.
RSS Feeds:
If you want to keep up to date on any category, or just want
to see if there have been any replies to your thread, then sign up for our RSS
feeds.  You can subscribe to a category or an individual thread.  The
process is the same for each options.  From the ¿Action¿ button choose
¿RSS¿.
If your RSS reader is set up correctly, you should now be
receiving RSS feeds.  Currently we support the Atom 1.0 standard.
Please check with your RSS reader¿s documentation to verify that it supports
Atom 1.0.
Subject: RE: Using These Forums
Replied by: Vikrant Bains on 26-04-2010 06:41:18 PM
Hi Chuck
I have a question here:-
1. Once we post our questions on the forums and they are answered, is it removed after sometime?
 I had posted a question which I am not able to view anymore
2. There were more code samples in the documents, which I was planning to use, but are no longer there. All I can see is ListMeetings file. Is it moved to some other location?
Vikrant
Replied by: Kingsley Lewis on 26-04-2010 07:59:58 PM
Hi Vikrant,
There are two different WebWx communities.  One for the WebEx Meeting services, and the other is for WebEx Connect.  These products are completely separate from one another.  If you have questions regarding the meeting service APIs please post them on this forum.
Thank you
-Kingsley Lewis
Replied by: Vikrant Bains on 26-04-2010 08:52:56 PM
In continuation to my questions, I posted my questions for the WebEx Meeting service and not the Connect client.
Can you help me get ans to the questions:-
These are for the WebEx Meeting Service
Thanks for your reply
Replied by: Kingsley Lewis on 28-04-2010 06:19:28 PM
Hi Vikrant,
Messages are not deleted from the forums, and we have never had anything other then LstMeeting sample code for the meeting services.  Are you sure you are not refering to the Cisco Webex Connect community where you have a question posted,  and also where we have a different list of sample code for that product?
Thank you
-Kingsley Lewis
Replied by: Vikrant Bains on 29-04-2010 04:37:47 AM
Hi Kingsley,
Yes you were right in evaluation. I posted my messages in connect forum instead of Meeting Services. Appologies for ignorance.
I can see the messages there now.
Vikrant
