cdnadmin
Community Member
This document was generated from CDN thread
Created by: ROD TAGUCHI on 31-10-2012 11:52:13 AM
I'd like to be able to create a post and see the email address associated with a post that I can send to people so they can reply and submit comments.  Currently, I can only get email messages for Posts that allow me to reply to comment IF someone else creates the post and I have my account Email notifications turned on to generate an email notification.
Currently for me to create a Post and generate an email from the post, I need to share with someone and ask them to send me the email that Social sends them.  This assumes that I send to someone with proper email notifications setup.
I'd like to be able to Create a new Post, generate an email with the entire post included, and send to people.
I'd like to have a button on the Post or in the Library action button to create and send an email to myself.  Or to generate an email address for email integration.
Thanks, Rod
Subject: RE: View/Create Email address for Posts
Replied by: Ratnadeep Ray on 04-11-2012 11:09:13 PM
Hi Rod,
Let me clarify a few things:-
1) Currently email notification will be sent only if you share the post with someone. But you are looking for a way to send the email notification to all your followers or whom you are following by default i.e. without sharing the the post just like the owner of the community gets an email when someone starts a discussion. Correct?
2) In the post/library, there should be a way in which you yourself will receive the email notification. Correct? Can you please let me know what all benefits you will get if you yourself receive that email. This info will be helpful to convince the DE's to add this feature.
Ratnadeep.
Replied by: ROD TAGUCHI on 05-11-2012 09:53:19 AM
I would like to be in a Post, while creating new or editing, and be able to send using my email program my post with reply to links to comment via email integration.  I would like the email that gets sent to be much like the email that goes via email notification when a post is shared with someone and they have email notifications turned on for shared posts. (include entire post with reply to link embedded for people to easily use email to submit a comment to a post).
If the system uses my own email program, I will be able to send to people or groups already setup in my email program.  If the system uses WxS to send the email, then I would like to be able to send the post to people, community members, or a WxS group.
Currently, If I create a post, there is no way of generating or knowing what the email address to comment on the post is and if I send email directly from the Post, the actual post content is lost.
Currently, I create a post, I share with a co-worker who then sends the post back to me and then I use my email program to send to many people.  I am using this for corporate newsletters that need to go to everyone in company, some may not be regular users of Social, and some are.
Ideally, WxS would send the message as opposed to using my email program and would eliminate duplicates for people that would normally already get the post via email notifications.
Rod
