Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: null on 22-01-2004 09:48:59 PM I'm building an application where I need to have the system read through a set of DB data (obtained via a Database action). After some research I believe I need to use VoiceElementConfig AudioGroups, calling the setElementData() method for each bit of data I can retrieve from the Database Action Element's ResultSetList. I've searched through the forums and some of the example apps and tutorials, but I haven't seen anything about VoiceElementConfig yet -- just the javadocs. Are there any good examples out there?
Am I looking for the wrong thing? Meaning, is there a simpler way to TTS a ResultSetList, and allow the user to select which "row" he wants to act on?
Example Scenario: User calls and wants to look for a local restaurant. Selects 'Italian' as a cuisine. DB retrieves 5 'Italian' restaurants. I want the system to list them, allowing the user to select which one he wants to get address/phone info for, etc.
Thanks in advance, -m-
Subject: RE: VoiceElementData construction examples? Replied by: null on 22-01-2004 10:24:27 PM Wait, I believe I can work from the UserProfileReadAccountInfo class from the Chapter 6 tutorial ("User Profile"). Sorry to bother.
If, on the other hand, you have a better example, I'd love to hear it! =D
-m-
Subject: RE: VoiceElementData construction examples? Replied by: Michael Bochynski on 22-01-2004 10:50:02 PM HI,
You are right, that's the best example. You might also want to look at [b:1bb5862294]Chapter 3[/b:1bb5862294] of our [b:1bb5862294]Tutorials[/b:1bb5862294] where the [i:1bb5862294]SayItSmart[/i:1bb5862294] plugins are used.
Regards, Michael
Subject: RE: VoiceElementData construction examples? Replied by: null on 15-12-2005 12:08:26 PM Hi,
I'm also looking for examples of using VoiceElementConfig. Can anybody let me know where to find the "Chapter 6 tutorial ("User Profile")" referred to above. Is there a book of tutorials available?
Thanks.
Subject: RE: VoiceElementData construction examples? Replied by: Michael Bochynski on 15-12-2005 02:21:47 PM Hi Eanna,
You can find tutorials and sample applications in the forum
You might also use our sample custom elements and SayItSmart plugins, available at Sample Java Code
Hope this helps, Michael
Subject: RE: VoiceElementData construction examples? Replied by: null on 15-12-2005 02:30:02 PM Michael,
Thanks. After a bit of delving I found a useful example in the Hollywood Hotel sample app.
