Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: null on 30-06-2005 08:48:09 AM Hi, I have tested a small application with the attached VXML file and it works fine. But I have inerted the same element into another application and as soon as it enters the VoiceXMl insert element, the call terminates and it doesn't even logs in the Activity log. It won't even show any logs for the next few calls. Do you have any idea what is happening?copy of the log follows. " insert_vxml4" is the VXML insert element name. [code:1:743bfa8098]148.182.200.85.1120087866868.40.ABSCollector,06/30/2005 09:34:16,AdviceMsgAction4,element,exit,done 148.182.200.85.1120087866868.40.ABSCollector,06/30/2005 09:34:16,insert_vxml4,element, enter, [/code:1:743bfa8098]
Subject: RE: VoiceXMLInsert Element logging issue Replied by: Vance Vagell on 30-06-2005 04:13:08 PM Hi Jaison,
Your VoiceXML code references the "audium_element_start_time_millisecs" variable in your MainMenuCLI menu, even though the variable is not defined until later, in the forms. This will cause an error at runtime.
For information about how this variable works, and exactly where it should be declared, please refer to the VoiceXML Insert Elements section of the User Guide. If you download the pdf, you can easily find the relevant section by searching for "audium_element_start_time_millsecs".
