cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 02-05-2006 02:43:10 PM
Does Audium have or recommend software to simulate VXML requests for call load testing
Subject: RE: VXML Load testing?
Replied by: Michael Bochynski on 02-05-2006 03:05:07 PM
Hi Dylan,
VoiceXML produced is an XML with a predefined set of tags and attributes, hence you can use any tool that is capable of sending HTTP requests and interpreting results. With that said, we, and several of our customers, use OpenSTA to run load tests.
Note, however, that this kind of tool takes gateway out of the picture, since it makes requests directly to the application server and thus Audium Call Services. If you want to run tests with gateway browser included, you would have to use tools provided by the gateway vendor.
Hope this helps,
Michael
