Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Santiago Salvador Figueroa on 30-09-2011 07:52:18 PM Hello I need help when I tried to do audio-prompt load 0.wav I get that:Reload of 0.wav status failed audio-prompt 0.wav not loaded - open (or format) failure Buti have another gateway vxml and this audio work ok. Another thing how can I to do a purge of audio in cache? Thanks.
Subject: RE: vxml problem Replied by: Ryam Hilfers on 30-09-2011 08:20:52 PM
Thanks.
You can use the command: set http client cache stale to force a conditional-get on all files in the cache the next time they are called in your application. If the file has changed on the media server, this should cause the gateway to reload the new file. -Ryan
