cdnadmin
Community Member
This document was generated from CDN thread
Created by: Satendra Gupta on 24-07-2011 02:19:13 AM
We are getting timeout issue at below
levels in IVR:
1)     At the very first entry level of the
application i.e. subdialog start block.
 2)  At any Menu Level( where we play menu level
prompts)  in IVR.
Getting following error:
A VoiceXML Session timeout occurred at element AIRCEL_MAIN_ST: A session has timed out after 3 minutes. This is most likely caused by a start of call class or action element at the top of the callflow not completing before the voice browser's fetch timeout occurred. To resolve it ensure this class executes in a timely manner or run it in the background. Session timeouts may also occur under high load or if there are issues with a load balancer or voice browser.
Have attached all the logs(Activity logs, debug log, error log)
Please suggest the resolution for the same.
Satendra
Subject: RE: VXML session timeout issue
Replied by: Hemal Mehta on 24-07-2011 09:53:32 AM
levels in IVR:
prompts)  in IVR.
Satendra
Ok, there can be several reasons for this and you will get the same error listed above.  Here are a few things you can check:
1. Make sure that there is no other error in your app, backend error. For example when you load the app and if you are executing any other java class or making a backend call, make sure that there are no errors there.  In the activity log you could  see the above error, if there is an error in the backend.  In my case most of the times, this error was coming because of some other isssue in the backend.
2. If you are using ICM make sure that the network VRU timeout is set to around at least 3000 sec instead of default which is set to 180
3. Change the session timeout value to atleast 5 mins
4. Do you have ASR? If not and you are using dtmf only make sure that you do not have any value set in voice (settings tab of MENU)
I
Subject: Re: New Message from Satendra Gupta in Customer Voice Portal (CVP) - CVP -
Replied by: Janine Graves on 24-07-2011 09:21:42 AM
You should be using CVP_Subdialog_Start, not Subdialog_Start. Also, do
not configure anything in the Settings tab for this element.
If the audio files for the Menu aren't retrievable by the gateway, I
also get error.noresource - so start there.
Turn on gateway debugging and see what's happening.
Do you have your default audio path configured?
Are you on 8.5? Lots of noresource issues being reported there.
On 7/24/2011 2:19 AM, Cisco Developer Community Forums wrote:
> Satendra Gupta has created a new message in the forum "CVP - All
> Versions":
> Hi,
> Â
> levels in IVR:
> Â
> Â 2) Â At any Menu Level( where we play menu level
> prompts) Â in IVR.
> Â
> Â
> Have attached all the logs(Activity logs, debug log, error log)Â
> Â
> Thanks:
> Satendra
> To respond to this post, please click the following link:
> <http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/4263650>
> or simply reply to this email.
Janine Graves
Replied by: Satendra Gupta on 24-07-2011 10:22:23 AM
Hi Janine ,
Thanks for the reply.
Yes I am using CVP_Subdialog_Start at the start. Settings for this element is default one, i.e. "Parameter"-> blank; Store As-> Session Data;Enable Digits Bypass->False.
Yes I've set the default audio path in "CallStart" class.
Versions are as:
ICM is 8.5.1 and CVP is 8.0.1
sure, I'll check at the g/w debug.
Satendra
Replied by: Satendra Gupta on 24-07-2011 10:34:23 AM
Thanks Hemal for the quick reply
Please suggest the config file,where I can change the "network VRU timeout" setting.
Satendra
