cdnadmin
Community Member
This document was generated from CDN thread
Created by: Heimo Stieg on 08-04-2013 09:28:19 AM
Hello, I've created a simple script to play an audio file and redirect it to the operator(CUCM).
It is working fine on PSTN calls, but as soon as the source is a SIP call, then the call will be transfered without audio.
Has the router be configured in a special way to use early-media with sip in a vxml application? Or am I missing something in the vxml script?
Kind Regards
Heimo
Subject: RE: VXML SIP Transferaudio
Replied by: Yaw-Ming Chen on 08-04-2013 11:11:24 AM
Can you plrase attached the dial-peer configuration for this vxml service ?
Thanks !
Replied by: Heimo Stieg on 09-04-2013 02:44:27 AM
The pots dial peer has the same configuration:
dial-peer voice 52 voip
 description "SIP Test"
 service tvmsip
 incoming called-number 4321T
The sip dial-peer:
voice class codec 10
 codec preference 1 g711ulaw
 codec preference 2 g729r8
 codec preference 3 g711alaw
dial-peer voice 51 voip
 destination-pattern [1-8]T
 voice-class codec 10
 session protocol sipv2
 session target ipv4:<IP>
 dtmf-relay rtp-nte
Replied by: Heimo Stieg on 09-04-2013 04:02:34 AM
Hi Raghavendra,
you can find the log in the attachement.
Thanks 😃
Replied by: Raghavendra Gutty Veeranagappa on 09-04-2013 03:49:13 AM
Hi Heimo,
could you please send us the logs by enabling below debugs.
debug voip app
Raghavendra
Replied by: Raghavendra Gutty Veeranagappa on 09-04-2013 04:02:07 AM
Hi Heimo,
please try to configure "codec g711ulaw" to your dial-peer 52.audio files also should be same codec.
Raghavendra
Replied by: Raghavendra Gutty Veeranagappa on 09-04-2013 04:24:01 AM
Hi Heimo,
from the logs it shows that play audio failed because of codec mismatch, please configure "codec g711ulaw" to your dial-peer 52.
Apr  9 08:54:20.737: //34//MSM :/ms_asDone_buginf: Stream Association Failed: Requested codec=0x5=g711ulaw, Negotiated codec=0x10=g729r8
Raghavendra
Replied by: Heimo Stieg on 09-04-2013 04:27:14 AM
Thank you Raghavendra
the missing codec in the dial-peer was the problem.
Heimo
