Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Silvia F Baptista on 01-11-2010 09:07:25 PM When converting VXMLServer 4.x or 7.x licenses to VXMLServer 8.0 licenses, customers must leave their old license in the C:\Cisco\CVP\VXMLServer\license folder. Then in the Operation Console Server go to System > License Conversion. Select the VXMLServer (s) that need license conversion, and hit "Convert" button. Then click on the "Conversion Status" button. If the conversion status was successful, you can click on the success link and copy the XML string from the popup. From the conversion status page you can select the VXMLServers and click "Export". From the exported file you only select the XML string that starts with <?xml version='1.0'?> and ends with </LicenseUpgrade>. See the attached picture. This XML can also be found on the VXMLServer in C:\Cisco\CVP\conf\license\licenseconversion.txt. Once you have the XML go to http://www.cisco.com/go/license. Type in the IP address of the VXMLServer. Paste the XML string generated by the CVP License Conversion utility. Read the License Agreement and click on the Agreement check box. Your new license will be emailed to you.
