cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Melissa Smith on 11-11-2010 05:37:40 PM
Is it considered "working as designed" if when you call out to a webservice using the built in web service element and get back information for set values and then try to call out to the same web service again later in the app to get back different set values and it returns back an error, null and routes out the error path?
Subject: RE: Web Service Built In Element in 7.0(2)
Replied by: Hemal Mehta on 14-11-2010 05:15:16 PM
Can you elaborate further on what exactly are you trying with backend calls, Are you getting two different responses with same input. What do you see in the logs?
