cdnadmin
Community Member
This document was generated from CDN thread
Created by: Nathan Galloway on 22-01-2010 06:05:40 PM
I believe I've read this on another topic on this forum, but can't seem to find it with the search engine being down.  I am looking for the element data name that the web service service element returns "fault" text in.  I believe that this ability is in there, outside of parsing it out in the full text response.  Please let me know if you can help.
Nathan
Subject: Re: New Message from Nathan Galloway in Customer Voice Portal (CVP) - Gener
Replied by: Janine Graves on 22-01-2010 06:49:55 PM
You could look at the element data named 'response_xml'' and parse it,
but I assume you're trying to avoid that.
Within Studio, go to the Help menu and select Help Topics and select the
Studio Users Guide, enter the Search term 'web services' - thats where
you'll find documentation on the Web Services element.  I think
response_xml is the only data returned.
Cisco Developer Community Forums wrote:
> Nathan Galloway has created a new message in the forum "General
> Discussion - All Versions":
> Hello,
> Â
> can help.
> Â
> Thanks,
> Nathan
> To respond to this post, please click the following link:
> <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/1914726>
> or simply reply to this email.
Subject: RE: Re: New Message from Nathan Galloway in Customer Voice Portal (CVP) - G
Replied by: Nathan Galloway on 22-01-2010 08:53:00 PM
It certainly appears by the help guide that I'll need to write some java to parse out the fault response.  Not sure why I thought I had seen differently.  I guess I could add this to the wish list enhancement forum.  Thanks for your help.
