cdnadmin
Community Member
This document was generated from CDN thread
Created by: Daniel Nikolov on 17-09-2012 03:14:13 PM
Hello All,
I have local instance of WebEx Developer Edition, run using VMWare Player.
However I have the following problem:
  When I try to execute REST call using Firefox (packed with WebEx VM image) REST client plugin, I can not execute it because it raises Http Error 500: Internal Server Error.
This is the rest call: GET http://localhost:80/api/quad/rest/communities
Content-Type: application/json
I am using Http Basic Authentication with username = test@your_company.com and password=quad
I have tried several other usernames/passwords but all I got is either Http Error 500 or User Account Error (Http 201).
Can anyone help with this issue ?
Subject: RE: WebEx Local Dev Instance - Problem with REST client
Replied by: Amanda Whaley on 18-09-2012 10:58:08 AM
Daniel -
By default, the Webex Social APIs use OAuth authentication.  You can enable Basic Authentication by following the instructions on this page: http://developer.cisco.com/web/webexsocial-developer/testing-the-apis.
Have you enabled Basic Auth for the APIs in this way?
Also, for the default installation of the VM, the username should be username = test@your_company.com and password=cisco.
Please let me know if you need anything else -
Amanda Whaley
Replied by: Amanda Whaley on 18-09-2012 03:19:05 PM
Great!
Amanda Whaley
Replied by: Daniel Nikolov on 18-09-2012 11:08:31 AM
Hi Amanda,
Yes, my Basic Authentication is enabled. I restarted the quad as described in the tutorial: sudo ./quad restart
It asked me for password for quad user which appeared to be "quad".
Subject: Re: New Message from Daniel Nikolov in WebEx Social Developer - API/SDK: RE
Replied by: Amanda Whaley on 18-09-2012 11:29:39 AM
Daniel -
The password for the system user is:
username: quad
password: quad
You are correct, this is the password to use when restarting the system.
To Authenticate the APIs, you need to use the WebEx Social portal user credentials.
The password for the WebEx Social portal user that is setup by default in the VM is
username: test@your_company.com
password: cisco
To authenticate the API calls in the REST Client:
select Basic Authentication
enter: Username:test@your_company.com
enter: Password:cisco
Please try that and let me know if you still have issues.
thanks -
Amanda Whaley
[email protected]<mailto:[email protected]>
Cisco Developer Services
On Sep 18, 2012, at 10:08 AM, Cisco Developer Community Forums wrote:
Daniel Nikolov has created a new message in the forum "API/SDK":
Hi Amanda,
To respond to this post, please click the following link:
<http://developer.cisco.com/web/webexsocial-developer/forums/-/message_boards/view_message/6520966>
or simply reply to this email.
Replied by: Daniel Nikolov on 18-09-2012 12:48:31 PM
Thanks, it worked out
