cdnadmin
Community Member
This document was generated from CDN thread
Created by: Adam Nosek on 14-07-2011 03:17:39 AM
do you guys know where can i find cmrtplib.lib RTP Library in order to work on applications' media management?
Thanks in advance,
Adam
amoherek
If you are using a 64-bit OS, the library has been renamed to ciscortplib64.lib and you can find it in C:\Program Files\Cisco\CiscoTSPx64\RtpLib\Include\
If you are using a 32-bit OS, the library has been renamed to ciscortplib.lib
