Tana Franko
Level 3
Level 3
The legacy system analysis ensures that you thoroughly understand the existing voicemail system usage from a technical standpoint. This step actually tells you how to configure Unity, allowing you to develop configuration details such as schedules, call handlers, and routing rules. If you skip a step in data collection here, you may end up under- or over-sizing your Unity deployment for the actual system load and usage.
