Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Bill Westby on 08-09-2010 09:05:13 PM I'm trying to write to a text file inside a decision element and can't get the output to flush into the file. I can create the files no problem but using standard BufferWriter technique to write the data produces no errors yet no data in the files, what am I missing here? Code snip:
ded.addToLog("INFO", "Checking if import file exists." + ciscoImportFile.getName()); if(!ciscoImportFile.exists()) { String entryString = "" + rtrCallKey.toString() + "|" + rtrCallDay.toString() + "," + dbqueue.toString() + "|" + dateTimePartPlusEWT.toString() + "," + custcbnum.toString() + "," + CTIRP.toString(); ded.addToLog("INFO", "Try to write data to import file: " + entryString.toString()); try { ciscoImportFile.getParentFile().mkdirs(); ciscoImportFile.createNewFile(); BufferedWriter outputWriter = new BufferedWriter(new FileWriter(ciscoImportFile.getName())); ded.addToLog("DEBUG", "Output writer: " + outputWriter.toString()); outputWriter.write(entryString); outputWriter.newLine(); outputWriter.close(); ded.addToLog("INFO", "Cisco import file written successfully."); } catch(Throwable thrw) { ded.addToLog("ERROR", (new StringBuilder("Error occurred creating file: ")).append(ciscoImportFile.getCanonicalPath()).toString()); throw thrw; } The activity log shows success and the data I'm writing: 10.0.18.170.1283979327615.22.DB_CallBack_AgentFirst,09/08/2010 13:55:27.786,CreateAgentFirstCallback_01,custom,INFO,Cisco import file path: \\10.0.18.164\d$\DialerImport\callback.txt 10.0.18.170.1283979327615.22.DB_CallBack_AgentFirst,09/08/2010 13:55:27.786,CreateAgentFirstCallback_01,custom,INFO,Checking if import file exists.callback.txt 10.0.18.170.1283979327615.22.DB_CallBack_AgentFirst,09/08/2010 13:55:27.786,CreateAgentFirstCallback_01,custom,INFO,Try to write data to import file: 151515|161616HelpLine|2010-09-08 13:55:27|60031096245591039821133 10.0.18.170.1283979327615.22.DB_CallBack_AgentFirst,09/08/2010 13:55:27.786,CreateAgentFirstCallback_01,custom,DEBUG,Output writer: java.io.BufferedWriter@1604bee 10.0.18.170.1283979327615.22.DB_CallBack_AgentFirst,09/08/2010 13:55:27.786,CreateAgentFirstCallback_01,custom,INFO,Cisco import file written successfully. 10.0.18.170.1283979327615.22.DB_CallBack_AgentFirst,09/08/2010 13:55:27.802,CreateAgentFirstCallback_01,exit,Success 10.0.18.170.1283979327615.22.DB_CallBack_AgentFirst,09/08/2010 13:55:27.802,CVP Subdialog Return_01,enter, 10.0.18.170.1283979327615.22.DB_CallBack_AgentFirst,09/08/2010 13:55:27.818,CVP Subdialog Return_01,exit, 10.0.18.170.1283979327615.22.DB_CallBack_AgentFirst,09/08/2010 13:55:27.818,,end,how,app_session_complete 10.0.18.170.1283979327615.22.DB_CallBack_AgentFirst,09/08/2010 13:55:27.818,,end,result,normal 10.0.18.170.1283979327615.22.DB_CallBack_AgentFirst,09/08/2010 13:55:27.818,,end,duration,0 Any help is always appreciated. Bill Westby Medtronic Diabetes
Subject: RE: Writing to text file using java in decision element Replied by: Bill Westby on 08-09-2010 09:55:54 PM Figured it out finally, had to use dataoutputstream methods for whatever reason...
