Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Keith Lunn on 27-06-2009 03:18:55 PM Hello Folks, Env: Win2003 Server, WSH 5.7, JScript, CUCM 6.13 A previous programmer wrote a JScript program to access our old CCM 4.13. I have a question on how SOAP is binded to HTTP for the AXL interface. Two parms are included with building the HTTP heaer using xmlhttp.setRequestHeader object: "Man" and "MessageTYpe" - what are these parms and what do they do. Cisco's Developer guide documents to build the HTTP header as such: The following example contains an HTTPS header for an AXL SOAP request: POST :8443/axl/ Host: axl.myhost.com:8443 Accept: text/* Authorization: Basic bGFycnk6Y3VybHkgYW5kIG1vZQ== Content-type: text/xml SOAPAction: "CUCMB ver=6.0" Content-length: 613 In the old 4.13 JScript program we have, the following code was used to build the header: var xmldom = new ActiveXObject ("Microsoft.XMLDOM"); var xmlhttp = new ActiveXObject("Microsoft.xmlhttp"); var SoapServer = "https://" + strCMHost + "/CCMAPI/AXL/V1/SOAPISAPI.dll"; //Build XML Header in xmlhttp object xmlhttp.open("POST", SoapServer, false); xmlhttp.setRequestHeader("Man", "POST " + SoapServer + " HTTP/1.1"); xmlhttp.setRequestHeader("MessageType", "CALL"); xmlhttp.setRequestHeader("Content-Type", "text/xml"); xmlhttp.setRequestHeader("Host", strCMHost + ":80"); xmlhttp.setRequestHeader("Authorization", "Basic " + strAuth); xmlhttp.setRequestHeader("Content-length", "478"); I cannot find any documentation on these two configs: xmlhttp.setRequestHeader("Man", "POST " + SoapServer + " HTTP/1.1"); xmlhttp.setRequestHeader("MessageType", "CALL"); These are not documented in the Developer's guide, neither are they documented with the setRequestHeader method, or the SOAP/HTTP binding RFC in http://www.w3.org/TR/2007/REC-soap12-part2-20070427/#soapinhttp. I have googled this code and found a few examples of programs in JScript using SOAP interaces and I see that they are also using these 2 structures but no one has commented on their purpose or use. Can someone tell me what hese two items are and what they do? Thanks!!!!
Subject: RE: xmlhttp.setRequestHeader Parms for AXL 6.13 Replied by: Keith Lunn on 27-06-2009 04:15:13 PM Folks, This is resolved! This code: xmlhttp.setRequestHeader("Man", "POST " + SoapServer + " HTTP/1.1"); xmlhttp.setRequestHeader("MessageType", "CALL"); has NOTHING to do with the AXL SOAP interface. Its required for a Google.com API specification. Apparently the programmer saw it in a JScript SOAP programming example and thought it was part of the SOAP/HTTP specification - it is not. Thx, Keith
