mbtilal
I want to know that how much length of camera control cable is supporting of edge 95
1 Comment
The Edge series when used with the PrecisionHD camera has specific and unique cable requirements. It is not recommended to extend these or build your own as wiring is non-standard so as to carry power, control and digital video signals on the one cable, which I believe were available up to 3 or 4 meters. However, to address longer requirements, Tandberg/Cisco did produce an extension cable for these cameras:
CAB-PHD-EXTR=. It requires use of a separate 12v camera power supply i.e PSU-CAM-V=. Up to three of these extension/repeater cables can be connected for a total length of 20 meters. Not sure if you can order these anymore.
