CUCM manual and auto backup procedure using GUIa
BalajiSivaraj49175
CUCM can backup the manually or have sehchduler  to backup the configuration and historical reports from the server diester recovery system
Step 1. Navigate to CUCM > Disaster Recovery System > Backup > Manual Backup as shown in the images:Capture1.JPG
Step 2. Select the Backup Device, the features to be backed up and click Start. For this example, only the UCM feature is backed up as shown in the image:
When the backup is in progress, you see a status indication as shown in the image:
When the backup is complete, you see a SUCCESS message that indicates the Backup Completed in CUCM as shown in the image:
When the backup is complete, you see the .TAR files in the SFTP directory as shown in the image. These files are used later one, if a restore is required:
Start a Manual Backup via CLI Procedure
Step 1. Secure Shell (SSH) into the IP address of the CUCM Publisher and authenticate with the OS username and password as shown in the image:
Step 2. Start a Manual backup with the command syntax: utils disaster_recovery backup network <featurelist> <backup device name> as shown in the image:
Enable Scheduled Backup via GUI Procedure
Step 1. Navigate to CUCM > Disaster Recovery System > Backup >Scheduler >> Add New as shown in the images:
Step 4. Select the features to be backed up
Step 7. Enable the scheduled backup:
Enable Scheduled Backup via CLI Procedure
Step 2. Add the scheduled backup with the command syntax: utils disaster_recovery schedule add <schedulename> <devicename> <featurelist> <datetime> <frequency> as shown in the image:
CUCM Delete an Old Backup Example
Backup device configuration with Number of Backups set to 1 as shown in the image:
Backup directory with only 1 backup available (16 files) as shown in the image:
CUCM first starts to transfer backup files before it deletes the old backup (Reaches 32 files):
Once the backup is complete, DRS deletes the old backup to be in compliance with the number of backups to store in Network Directory (16 files):
Log Analysis of Successful New Backup Created and Old Backup Deleted
The message you see when a manual backup is started: BEGIN MANUAL
2018-12-25 11:11:59,486 DEBUG [NetMessageDispatch] - drfMessageValidator.validateMessage(): Starting introspection for Message ID = 1700 Message Body =
========== BEGIN msgSubBackup_REQ ==========
m_bLeaveTempBackupDirectoryInPlace : false
destinationId : TAC-Backup
backupType : MANUAL
featuresTobeBackedup : [UCM]
========== END msgSubBackup_REQ ==========
This is the device that was added as a backup device: TAC-Backup
2018-12-25 11:11:59,486 DEBUG [NetMessageDispatch] - drfMessageHandler:HandleBackup: The backup is being processed for the device: TAC-Backup
Ensure SFTP is accessible
2018-12-25 11:11:59,487 DEBUG [NetMessageDispatch] - drfMessageHandler:HandleBackup: Executing sftpLsFiles to make sure SFTP is accessible.
2018-12-25 11:11:59,487 INFO [NetMessageDispatch] - drfUtils:sftpLsFiles-: Executing JSCH SFTP ls command for: User: ciscoHostName: 192.X.X.250 from source :/UCM/Backups/ with pattern -l
2018-12-25 11:11:59,487 DEBUG [NetMessageDispatch] - drfUtils:establishSftpConnection: Trying to connect to the SFTP server.
CUCM connects to remote SFTP server
2018-12-25 11:11:59,617 DEBUG [NetMessageDispatch] - drfUtils:establishSftpConnection: Authentication Completed Successfully, connected to remote server. Now opening a SFTP channel.
Number of features that were selected:
Found 1 features selected
Feature Name: UCM
2018-12-25 11:11:59,834 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Found 1 features selected for Restore
2018-12-25 11:11:59,834 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: CDPAGTDirectBackup set to : yes
2018-12-25 11:11:59,834 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: SYSLOGAGTDirectBackup set to : yes
2018-12-25 11:11:59,834 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: PLATFORMDirectBackup set to : yes
2018-12-25 11:11:59,834 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: CLMDirectBackup set to : yes
2018-12-25 11:11:59,834 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: CCMDBDirectBackup set to : yes
2018-12-25 11:11:59,834 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: TCTDirectBackup set to : yes
2018-12-25 11:11:59,835 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: CCMPREFSDirectBackup set to : yes
2018-12-25 11:11:59,835 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: TFTPDirectBackup set to : yes
2018-12-25 11:11:59,835 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: MOHDirectBackup set to : yes
2018-12-25 11:11:59,835 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: ANNDirectBackup set to : yes
2018-12-25 11:11:59,835 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: BATDirectBackup set to : yes
2018-12-25 11:11:59,835 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: CEFDirectBackup set to : yes
2018-12-25 11:11:59,835 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: REPORTERDirectBackup set to : yes
2018-12-25 11:11:59,835 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: DNALIASLOOKUPDirectBackup set to : yes
2018-12-25 11:11:59,835 DEBUG [NetMessageDispatch] - drfMessageHandler:setComponentBackupType: Feature Name: UCM. Server Name: D3-SB-11PUB. Component Name: DNALIASSYNCDirectBackup set to : yes
33 files found at the given path
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 33 files found at the given path
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_PLATFORM.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_drfComponent.xml
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_REPORTER.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_CLM.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_DNALIASSYNC.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_REPORTER.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_MOH.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_BAT.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_CCMDB.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_SYSLOGAGT.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_CEF.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_CCMPREFS.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_CCMPREFS.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_TCT.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_CEF.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_PLATFORM.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_CDPAGT.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_ANN.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_SYSLOGAGT.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_TFTP.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_TFTP.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_CCMDB.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_ANN.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_DNALIASSYNC.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_DNALIASLOOKUP.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_CDPAGT.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_MOH.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_CLM.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_DNALIASLOOKUP.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_BAT.tar
2018-12-25 11:16:23,886 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-24-13-21-17_D3-SB-11PUB_UCM_TCT.tar
This is used to keep track of number of backups:
DRS gets a list of its previous backup IDs:
2018-12-24-13-21-17
2018-12-25-11-12-03
2018-12-25 11:16:23,887 INFO [TarWorkerThread] - drfSftpManager:drfGetListOfBackups: Adding the backup id after the _pubhostname filtering:2018-12-24-13-21-17
2018-12-25 11:16:23,887 INFO [TarWorkerThread] - drfSftpManager:drfGetListOfBackups: Adding the backup id after the _pubhostname filtering:2018-12-25-11-12-03
list size : 1
2018-12-25 11:16:24,852 INFO [TarWorkerThread] - drfSftpManager.RemoveOldBackupSet: list size : 1
CUCM removes: /UCM/Backups/2018-12-24-13-21-17_D3-SB-11PUB*
2018-12-25 11:16:24,852 INFO [TarWorkerThread] - drfSftpManager.RemoveOldBackupSet: Removing: /UCM/Backups/2018-12-24-13-21-17_D3-SB-11PUB*
List now only has 1 backup
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 18 files found at the given path
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_REPORTER.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_CLM.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_MOH.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_BAT.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_CEF.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_CCMPREFS.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_TCT.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_PLATFORM.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_CDPAGT.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_ANN.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_SYSLOGAGT.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_TFTP.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_CCMDB.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_DNALIASSYNC.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_UCM_DNALIASLOOKUP.tar
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: 2018-12-25-11-12-03_D3-SB-11PUB_drfComponent.xml
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfutils.sftpLsFiles-: Found 16 matching the search criteria.
CUCM closes ChannelSftp...
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfUtils:closeSFTPConnections: Closing ChannelSftp...
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfUtils:closeSFTPConnections: Disconnecting Channel...
2018-12-25 11:16:26,405 DEBUG [TarWorkerThread] - drfUtils:closeSFTPConnections: Closing Session...
BACKUP operation COMPLETED
2018-12-25 11:16:26,572 INFO [TarWorkerThread] - {STATE_IDLE} drfBackup:CompleteBackup(Device=-): === BACKUP operation COMPLETED ===
0 Replies 0
