Hi,Could you please help me to find Warranty/Smartnet entitlement using Serial Number.
HiI would like to block incoming call from 1-2 number, i tried creating a rule to reject but not working...extracts of my rules are give below, am I missing something here? voice translation-rule 2rule 1 some old rules.....rule 2 some old rules.....r...
I have strange issue on small VoIP network running on 3 CME routers. The network is pretty static and unchanged for 10 plus years, and working fine as configured. I upgrade the 4451x routers fro 17.9.6 to 17.12.05a recently and after doing so, the Vo...
I feel like im losing my mind here. Im using the browser version of visio and trying to import the stencils from cisco's website. Problem is they aren't ".vssx" extension and its not reading the file due to compatibility issues. How to i get the cisc...
HelloI have two SIP trunks from the same SIP provider. and i am facing issue with incoming calls as they targeting the wrong SIP link .Noted in sip/sdp massage from my VGW to ISP contains the wrong SIP address (c=IN) ,dial-peer and sip bind configur...
Does anyone face this issue on virtual CUBE(CSR1000V), where you can't place any calls from webex calling cloud for particular time and after that it starts working fine. During that time period, i am getting below error message: 000134: *Sep 28 15:2...
CUC Call Handler Extension / Menu Options/ several have Pilot numbers to in CUCM for hunt group options. If that call is not answered need to be able to leave message in the Call Handler Extension numberCall Flow Entry Call handler Extension / Select...
Good Day Experts,Another day another authentication problem with Telco's.CUCM > Cube > Telco with SIP authentication.I am struggling to get this to work and I am trying to get this pointed towards an ISP issue but I need to confirm our side is clean....
Our company has several Cisco Room Kit pro's room kit bar pros. They are running Teams Meeting Room on all devices all on RoomOS 11.23.1.8 In some rooms we have a button to join Zoom calls via SIP, it's "hidden" on the side panel when we pull it out...
Ok, don't laugh because the answer seems kind of obvious but I have to ask... What is the difference between paying for dual display capabilities versus using a switcher with multiple monitors?I am guessing there has to be a visual difference (clone ...
Hi, I'm working on a cisco project and i need to link my catalyst to the DNS Spaces. As I'm setting up Spaces Connector OVA, i open the .ova file using virtualBox, type host ip, gateway and mask. However, no matter what I put I'm not able to proceed ...
I am working on a new solution for a customer with over 300 sip trunks from several different carriers all coming into our network then out to locations around the country through our internal network. I am trying to consolidate all of the sip trunk...
Does anyone have a mls qos template for a Sup7203bxl and/or 2T that will prevent random scanning traffic from flipping the control plane over? We noticed if you just send random traffic self IPs or broadcast/network IPs on these devices they just sor...
I have experience working in network technical support, but my studies are in a different field (foreign languages). Several friends have told me to try applying to Cisco and take their free courses, but I'm afraid because I haven't studied anything ...
Hello, I am looking to replace a Codec Pro codec with Quadcam (first version) for a new Codec EQ with reuse of the Quadcam (so no version Quadcam2). Does anyone have experience or advice if this will work? Purpose is to introduce USBC passtrough for ...
Subject | Author | Posted |
06-04-2025 07:12 AM | ||
04-19-2025 04:07 AM | ||
04-02-2025 09:00 AM | ||
03-22-2025 10:34 AM | ||
03-17-2025 03:19 AM |
