TCC_2
Level 10
Level 10
Core Issue
Low Latency Queueing (LLQ) is the key prioritization technique for enabling voice and data integration.
Resolution
To configure Low Latency Queueing (LLQ), perform these steps:
  1. Create a class map for Voice over IP (VoIP) traffic, and define a match criteria.
  2. Create a class map for VoIP signaling, and define a match criteria (optional).
  3. Create a policy map, and associate it to the VoIP class maps.
  4. Enable LLQ by applying the policy map to the outbound WAN interface.
These documents provide useful information on Configuring Class-Based Weighted Fair Queuing (CBWFQ) and LLQ. They also provide a number of other good sources on configuring Quality of Service (QoS) for voice:
BOB ATKINS
Community Member
These configuration do not work on Cisco 7513 routers with the following configuration:
RSP16 (Max memory)
VIP4-80 (Max memory) channelized DS3 blades
After running extensive tests we have found very poor QoS performance and high voice jitter and packet loss during period of heavy bulk data transfer.
