pkinane
Please rate helpful content (i.e. videos, documents, comments). Also, please select the correct answer(s) if any comment(s) answer your question otherwise the questions remains on the support forums as unanswered.
For CUCM you can enable DNS at installation; however, if you do not enable DNS at installation there is a way to do it later. Some people don't have a need to enable DNS at installation, but at a later date they require DNS for something (FQDN for the subject CN of a certificate, IM&P integration, etc....) and they need to use the second option of enabling DNS from the CLI. This second option is not very well documented so I created this video to help demonstrate the process.
The demonstration:
https://www.youtube.com/watch?v=aQ-1yh3ya-0
Summary of the process
Things to do prior to enabling DNS:
1: Check database replication
2: Perform a backup
3: Confirm there are no ITL issues. If you don't check this your phones might have issues later.
4: Make DNS entries in your DNS server so the IP address resolves to the correct FQDN and the FQDN resolves to the correct IP address. This can be tested with nslookup from a PC that uses the same DNS server the CUCM will be using.
Things to be mindful of when enabling DNS
1: All of your certificates will be regenerated and any CA signed certificates will be replaced with self-signed certificates
2: IT IS EXTREMELY IMPORTANT THAT ONLY ONE SERVER AT A TIME HAS A CHANGE PERTAINING TO THE DOMAIN NAME (GOING FROM NO DOMAIN TO HAVING A DOMAIN, CHANGING AN OLD DOMAIN TO THE NEW DOMAIN, REMOVING THE DOMAIN ALL TOGETHER). THIS HAS TO DO WITH THE SECURITY BY DEFAULT FEATURE AND THE FACT THAT ENABLING DNS REGENERATES ALL OF THE SERVERS' CERTIFICATES. ENABLING DNS ON ALL SERVERS IN THE CLUSTER WILL RESULT IN THE PHONE REJECTING ALL CERTIFICATES AND SIGNED FILES THAT IT RECEIVES FROM THE CUCMs.
3: Once you are done making DNS changes on your servers, reboot all servers in the cluster (even if some didn't have DNS changes, reboot them all)
Things to do after DNS is enabled:
1: Check database replication, and confirm there are no ITL issues as was done prior to the change.
2: Change the name listed under system server (this is optional unless you have a reason to do this)
If you are wondering why my licenses didn't need to be rehosted in this demonstration: CSCul10528 and CSCuj83605
This is the document I mentioned for understanding the output for "utils dbreplication runtimestate"
https://supportforums.cisco.com/document/12710871/undertstanding-output-utils-dbreplication-runtimestate-cucm
Vivek Batra
Thanks for sharing [+5].
- Vivek
pkinane
Thank you, Vivek.
The video is marked private and cannot be played.
