04-28-2013 07:24 PM - edited 03-12-2019 10:00 AM
This document explains the various Unified Communications call flow scenario in an Enterprise Network. Idea of creating this document is to help the beginners to understand the various Call flows and protocol messages.
In this scenario, Phone A is registered to Cisco Unified Communication Manager X denoted by CUCM X. Phone B is registered to the same CUCMX.
A call is placed from Phone A (1000) to Phone B (1006). Basic setup for a call between two IP phones registered to the same CUCM.
Below call flow illustrates the sequence of Skinny Call Control Protocol (SCCP) messages exchanged between the Unified CM (CUCM X) and the two IP phones described in the setup.
In this scenario, Phone A is registered to the Unified CM (CUCM). Phone B is connected to a carrier’s central office (CO) Switch. CUCM will access Phone B through the voice gateway. Below diagram illustrates this basic setup for a call set up between an IP phone registered to the CUCM and another phone connected to a CO switch in the public switched telephone network (PSTN) through a voice gateway. This voice gateway is registered with the CUCM using Media Gateway Control Protocol (MGCP).
A call is placed from Phone A (1000) to Phone B (555-1212). Phone A will hang up first. MGCP is used to relay ISDN messages that go between the CUCM and the actual CO switch.
Below figure, include call flows that show ISDN messages going to the gateway (GW); they are really being sent to the CO switch through the gateway. Detailed call flow is shown here,
In this scenario, Phone A is registered to the CUCM. Phone B is connected to a carrier’s CO switch. Below diagram illustrates this call setup between two IP phones registered to the same CUCM. A call is placed from Phone A (555-2001) to Phone B (555-2001). Phone B hangs up first. The CUCM must register with the gatekeeper prior to placing any calls, and the gatekeeper will police the bandwidth by implementing Call Admission Control (CAC).
Because the initial call setup phases between the IP phone and the CUCM have been covered earlier, they are not repeated in this call flow. Below figure includes all the steps involving CUCM registration with the gatekeeper, skips the initial IP Phone A interaction with the CUCM when it goes off-hook to call Phone B in the PSTN, and then illustrates the CUCM and H.323 gateway interaction, including the ISDN Q.931 messaging exchange with the CO in the PSTN to set up the call with Phone B. The communication beyond the CO, which would include SS7 messages, with the CO serving Phone B is not part of this overall example.
Thanks for the Explanation with detailed Call flow...
Thank you Saravana.
Thanks for the detailed flow.
This is awesome. Thank you very much!!
I could not understand the third call flow.
as you mentioned Phone A and Phone B both are registered on same CUCM then what is the need of Voice Gateway?
It would be appreciated if someone explain me.
Parm
