Cisco Jabber Guest SDK
rabdallah
Dear Sir,
We are trying to build a web application in which we want to make video calls with users using another web application. The video should be opened in iframe inside the web pages. I believe Jabber Guest SDK is helpful and can meet our needs. After browsing through the documentation, and trying the demo, I noticed that the Jabber guest client communicates with CUCM through endpoints https://[cucmserver]/cjg-api/rest/links. These REST endpoints are not reachable and they are generating error code 404 Page Not Found. I have installed a CUCM server and it is working fine but I don't know how to configure it to expose the rest links. In other words, how to install the Jabber Guest API and access the Jabber Guest Administration web pages, what are the required software components? Is Cisco Expressway product required?
Note: I tried Jabber Web SDK (not Jabber Guest) inside iframe, the video connection was established successfully but the docking of the video window inside iframe failed due to an error in javascript. When I used the same code in a web application (not inside iframes), the video and docking worked and all was successful. I came out to the conclusion that maybe CISCO Jabber Web SDK cannot be used in iframes and I should use CISCO Jabber Guest Web for that purpose. Please correct me if I am missing something.
Thank You
npetrele
Cisco Jabber Guest hasn't been updated since 2020, so I wouldn't go that route. In fact, as far as I can tell, all Jabber products are reaching their end-of-life. There are migration notes at the end of this page:
https://www.cisco.com/c/en/us/products/collateral/unified-communications/jabber-windows/eos-eol-notice-c51-2412157.html
npetrele
