04-12-2023 02:40 AM
Dear Dev Community,
I have some questions, which I would like to ask from you guys.
I’m interested in the topic of Netconf usability on Catalyst 9800-40.
Is it available (usable) in SSO (active-standby) mode?
I saw some topic, that it can be used for monitoring the standby wlc.
What about the active one?
Waiting for your kind response.
Kind regards,
Balint
Solved! Go to Solution.
04-12-2023 05:14 AM
As I said, DNAC uses netconfig in order to manage the WLC and not only they manage WLC with SSO but you can configure the SSO using the DNAC, so, based on that, I am pretty sure netconf works with stand alone or HA WLC.
04-12-2023 03:30 AM
Netconfig is an API and can be used in any device that supports it. 9800 does support Netconf either in Active or standy.
Cisco DNA Center use Netconf in order to manage devices like 9800 and you can benefit from it if you build your code.
04-12-2023 03:42 AM
From what i read, only GET (no copy-config etc) commands Document can be used on the standby/ Redundancy Management Interface (RMI) which is ok for monitoring the standby.
Hope this helps.
04-12-2023 04:26 AM
Thanks for the answers!
bigevilbeard , I mainly would like to monitor the active WLC.
04-12-2023 04:33 AM
If you guys read the netconf protocol's description, there is a sentence, that makes me uncertain, whether I can use it or not.
"The NETCONFfeature is notsupported on a device running dual IOSd configuration or software redundancy."
04-12-2023 05:14 AM
04-12-2023 05:19 AM
I understand now Flavio.
Thanks for the explanation and for your help!
04-18-2023 02:55 AM
I found an offical information in terms of netconf usability on HA systems.
source: https://www.cisco.com/c/dam/en/us/products/collateral/enterprise-networks/nb-06-ios-xe-prog-ebook-cte-en.pdf (page 76)
