how to change vrf interface with NSO
jvelilla
Hi, anybody knows how to change vrf name and re-apply the same ipv4 address and ipv6 address.
I configure "no ipv4 address" and "no ipv6 address" and change the vrf name, then when I configure the same ipv4 and ipv6 address the result is an error.
IP is mapped to VRF
so you need to delete VRF first wait for Router to delete it
then config new VRF with new name
apply it to interface
config IPv4 & IPv6 to interface
I'm sorry, I think I expressed myself wrong before.
What I want to do is build a service that changes the VRF or adds a VRF on an interface with configured ips. To do this I have to delete them first, apply the new vrf to the interface and reconfigure them.
NSO does not configure the ips for me if they are identical to the ones I have previously deleted, I suppose that it does not understand that it has to configure them after applying the VRF
