Question about GIt Bash
davidcriollo
I have this because i'm doing cisco devnet course Chapter A Brief Introduction to Git and then i got this "On your workstation, open the intro-python/git-basics/change_me.txt file on your computer and make a change - add, edit or delete anything you like. Then run the following commands:_" How can i do it with Git Bash???
@davidcriollo you could use vi / vim or Nano for this, for example
 vi difference1.txt
 vim difference1.txt
nano difference1.txt
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
balaji.bandi
First you need to clone the Project form git  ( get to local Linux)
git clone  http://-------------------url of project
Once you got the prokject download.
My favourite toool vi promgram.txt to edit
Vi command :
https://www.thegeekdiary.com/basic-vi-commands-cheat-sheet/
BB
