Run into"Virtualized Intel VT-x/EPT is not supported on this platform"
wgebe
Unfortunately, CML2 no longer works. At least I again encounter the message "Virtualized Intel VT-x/EPT is not supported on this platform". I had it running in its entirety last week by turning off hyper-v and WSL.
16 Replies 16
Hi there!
I went to your website but unfortunately, the 2 links you included that helped you fix this issue no longer work, and I could not find them in the Broadcom/VMWare communities.
You mentioned that one of the key items was "the group policy feature" change you did. Could you please elaborate on what you did for this?
I already disabled DeviceGuard from the Local Computer Policy(Registry Editor). I also disabled VBS from GPedit). Is that what you meant?
Thank you in advance!
Martin L
Also check CLN community CML forums at
https://learningnetwork.cisco.com/s/communities
find CML sub-forum ; in case of CML urgency, add post/reply and mention Karlo (using @ symbol )
Regards, ML
**Please Rate All Helpful Responses **
